I have a 98 3.0L Merc
I pulled the boat out of the water and trailered it home. I get home and I pull the carb for an overhaul. I put the carb back on and try to start it and the boat just clicks. Doesn't turn over. So I get out my volt meter and the battery reads 12.55 volts. Is the battery the cause of my problems or should I be looking somewhere else? Manual says it may be a faulty neutral switch. If the battery is not my problem where do I go to next?
