sugar sand heat spark
Leandro
Hi, i'm new here i got a jet boat with 120 hp inboard mercury
i would like to know i whta forum i have to go .
i run the boat last week and runs good and now i don't hacve any spark?
any suggestion
thanks
woody66912
Re: sugar sand heat spark
do you see a red cord hanging from the run switch on the control box.
Ayuh,.... Welcome Aboard,.....
The Jet-Ski forum would be your Best Bet.....
Zamboni
any suggestion
thanks
Most SJ threads are in the PWC forum, there are some in the merc outboard forum also. Basically the SJ's are hybrids-outboard powerheads mounted on a jet pump.
Suddenly lost spark?...first thing to check on these engines is the rev limiter (if kill switch is on). Disconnect the black/yellow wire from the rev limiter and see if the engine runs
post your engine problems in the inboard/outboard forum.
Leandro
ok,i'm sorry but i'm not sure where is that rev limiter i have a square box ,with something like a transparent yellow acrilic with some circuits inside.
it's that one
thanks
Zamboni
PM'd you a link to the manual-pics & diagrams should make this clear.
gold1422
I too am having the same problem on my regal rush with a 90 hp mercury sport jet engine. I disconected the black / yellow wire from the rev limiter and now I'm getting spark but the engine doesnt seem like it wants to start. I just bought the boat, the guy I bought it from told me it just needed a starter. So I replaced the starter and then ran into this spark problem. Shouldnt the engine still start with that black / yellow wire disconnected, does this mean the rev limiter is bad? Also when I crank it over, while getting spark, I have fuel pouring out of my carb breaters. Does this mean it may be out of time? Do I have to fix the rev limiter before I move on? It doesnt seem like a got a steal only buying the boat for $1000, now that I running into these problems?
