Re: replacing points 68 20hp johnson
Welcome to iboats!
Replacing the point sets is easy. Physically replace one set at a time. Use the second set as a wire guide to show you where the wires go. To adjust the point gap, rotate the crank shaft until the crank shaft key way aligns with the point sets rub block (the part that contacts the point cam). Set the point gap for .020.
Rotate the crank shaft 180 degrees, and again line up the crank key with the rub block for the second point set and set for .020.
The fiber 'wick' is an oiler. Replace the original with the new one supplied. The felt should contact the point cam and lubricates the cam surface.
