motor runs good without top
g-noles
i have a 1978 70 hp evinrude prof. rebuilt carbs new coils runs good but when i put the cover on it sounds like it chokes out and dies why would this be please help me
woody66912
Re: motor runs good without top
sounds like you have exhaust leak base gasket?
g-noles
ok you were rite so how much do u think it should be to have it replaced and would it even be worth it on a 1978 motor, some of the bolts are broke and need to be drilled and taped also so i just dont know if it would be worth fixin???????
samo_ott
If you want a cheapo fix, run a fresh air tube from the outside to the carb inlet.
g-noles
yes could run the fresh air line but it is not only leaking fumes it is spitting out water as well so i dont want it to over heat
wilde1j
Just replace the gasket, if that's all that's wrong.
kenmyfam
I would go with the gasket replacement if that is what the problem is. If there is nothing else wrong with the motor it is a good investment.
