thunderroad
Thread starter- Joined
- Jun 19, 2005
- 417
SN 2497444. It runs great at high rpm but if I have to idle or putt around long it starts sputtering. A short run at WOT gets it squared back up for a while but as the day progresses, even that doesn't clear it up. Early on, it starts fine when hot, later in the day, not so well. Temperature stays in the green at all times. Also...when I pulled it out of the water yesterday, I noticed the rear water line was a lot more black with exhaust soot than normal. Now..I did more idling than normal yesterday . I took the plugs (new NGK BR9ES gapped at .035) out today and they really didn't look all that black. Points are new, dwell is within range. Timing is 6 BTDC. New plug wires. New fuel filter. Took the carb apart this morning and cleaned all the passages. There was a little gunk present, but not all that much. It sounds fine on the muffs right now, but it did yesterday morning before I went out too.
Anyone have any ideas about something I should check?
