Ok I have a 96 johnston 3cyl 25 hp, J25TKLEDC. The problem is an intermittent one though it happens more often then not. The engine will start up fine and idle great, when I put it gear and give it the gas the engine will 1. bog and likely stall, or 2. bog eventually surge then stall, 3. just continue to bog, or 4. run fine(though rarely). If I do get the engine to run right after it cools down the problem reoccurs. So far I have replaced the tank line, the fuel filter, the spark plug wires, and the spark plugs. I have tested ok for spark on all three cly at idle, I have disconnected the key and kill switch with engine running to rule out a switch problem, and I have confirmed that the floats are full of fuel after a stall. So although it sounds like a fuel problem to me when it dies, is it possible that the ignition circuit is being broken when the motor revs up? Is this the power pack? What exactly does the power pack do? Could this be a carb problem?
Thanks.
Thanks.
