evinrude engine problem
spicerak
when i first use boat in morning it runs fine if i go 8 to 10 miles and let it sit for a while then when i try to go it will bog out unless i hold the choke in when i hold it in the it starts to pick up rpms and then im good to go untill the next stop.carb problem or could it be something else are they hard to work on dosent seem it thanks for the help
bigpoppakdog
Re: evinrude engine problem
I'm sure your going to get the what's the model number, year questions. You'll probably hear that since you choke it and it works you are not getting enough gas. Carb repair/clean, check fuel lines. Again its hard to say without knowing what your motor is.
