Re: 302 or 351
Although it is likely a 351w, 302's w/ 4 bbls were rated at 225 hp. Measure the width of the intake mani. If it is 11 or so inches then it is a 351, if it is 9 some inches wide it is a 302.
Not from what I recall, back around 1974,
I had an 18' Wellcraft Airslot with a 302/188hp Mercruiser with a 2bbl back then, and I made it a point to research, check, & see what the maximum horsepower a 4bbl would give me, it was only 215HP! or approx. 27hp more then the 188. This was all a futile attempt though, because I searched high, & low, to find a carb, & manifold, they were rarer then hens teeth! I wasn't gonna buy them new, too pricey! and I couldn't use an aftermarket aluminum manifold in salt water. I probably would have bought a new carb, if I'd have found a used manifold, but it wasn't to be.
If you had a 225hp Ford V8 back then, it was a 351 with a 2bbl!
