1999 Merc 75 HP stalling
sledstew
I have a 1999 merc 75 HP that will start and run for a few seconds then stall out, any suggestions are appreciated.
Barnacle_Bill
Re: 1999 Merc 75 HP stalling
When it starts to die try pumping the primer bulb. If it acts like it wants to run, rebuild the fuel pump. Be sure to get the kit from Merc as it will include new style check valves.
tredragon
you can also try adjusting idle speed and/or idle mix. you might be running rich and have a low idle, or either one individually. check mercruiserparts.com for your motor's S/N and it'll show you all the parts.
