Re: nineteensixtycaddy here's your post 35 hp wiring
Ok... can't take any photos, don't have digital, and wal-mart get's expensive.
but here's what I can tell you.
Wired up the positive and negative to the battery leads, and wired one black from the magneto into the positive, and one to the negative. Well, THAT was dumb, as I should have read the responses here first. The wires got REAL hot going to the magneto, and smoked a lil bit, and I disconnected them as FAST as I possibly could!!! Then, I came back, read the responses, and tried again.
This time, put the positive and negative to the battery leads, put a switch on the black wires from the magneto, in the OFF position, so that they were not connected. Then pulled the rope start. I pulled and pulled, and pulled, and pulled. Got some smoke, and a couple backfires. I figured that was a pretty good sign that I have spark of some sort.
The throttle is on the port side, and it's hooked with a cable to a dual lever control.
The gear selector is on the starboard side, and hooked with a cable to the other lever on a dual lever control.
Both the throttle and gear select controls and cables work fine.
The fuel line is connected to a wal-mart boat gas tank, with a bulb, and when I squeeze it more than once, fuel comes out the carb on the motor, so I know it's getting plenty of fuel, if not TOO much.
The bow end of the outboard has a manual choke lever, out for choke, in for off.
When looking at the outboard from inside the boat, the choke is on the left.
Then in the middle, there is an adjustment screw for idle speed, left for rich, right for lean.
on the right there is an adjustment screw for high speed, left for rich, right for lean.
Oh.. one more thing. Connected the green from the makeshift starter solenoid/relay thingie. It turned the starter some, but not enough to crank it. After a few tries, it got pretty hot, so I rigged a jumper wire from the starter directly to a switch hooked to the positive on the battery. Flipped the switch, and WOW did she try to crank. Over and over and over she tried to crank.
Got plenty of smoke, but no firing. No backfire even.
so.. took out the plugs, both oil and or fuel soaked. So I'm letting them dry right now, and typing, and hoping to go right back to put em back in and try again.
Wish me luck, and any ideas are VERY welcome.
Thanks
Chris
