littlebookworm
Thread starter- Joined
- Nov 30, 2007
- 574
Hi, all: Getting ready to drop in my Mercruisr 5.0 into my SunRunner. I decided to used the engine mounts from the replacement engine because the old mounts were shot. At home, using a come-along and a garage rafter, I lifted the engine off the dolly slightly and swapped out the mounts. Went to the marina to install the "new" mounts and was surprised that the lag bolts wouldn't fit through the holes in the base of the mounts. The "new" mounts used a3/8" lag bolts rather than the 1/2" bolts on the old mounts. Took the mounts home and drilled out the base holes to slightly over 1/2". I had planned on preinstalling, loosely, the mounts into the engine bay, and then later dropping the engine onto the center bolts and rear mounts. After reading one of the other posts, I'm not sure whether or not I should do it that way or if I should install the mounts on the engine and deal with aligning the mounts' bases, blocks, and stringer holes to screw in the lag bolts. Any suggestions?
