jtcarter
Thread starter- Joined
- Apr 26, 2008
- 226
Well i've done about all i know to do to this motor to get it running right but it refuses. I have recently did away with the vro and went with a electric fuel pump and premix. It runs the same as it did when i had the vro on it. It still lean sneezes despite having the idle screws run out about two to two and a half turns out of spec. Its almost starting to run rough now i suspect the screws have it running rich now. Anyway spark is good,compression is good,brand new stator,new coil packs and wires. No obvious fuel leaks and the fuel pump isn't the problem. What else in the world could it be. Vent on gas tank is open. I have went through the carbs also. Went step for step with the manual. Motor doesn't run diferent with motor tilted so floats i rule out. Possible gasket leak on manifolds? Fuel rails have no gas or oily residue on them and i checked the o-rings. I have a new power pack also. Could a recirculate valve be clogged if so how do you check it. Man i'am all ears.
