1992 Evinrude 200 Xp very slow hole shot
basserjim2
Motor runs fine when cool, idle, gets on plane quickly, good top end.
After it warms up, or high air temps: very slow getting on plane, idles rough, when shifting from nuetral to forward often stalls. very annoying problem
The carbs have new kits, timming, compression good, lynk/sink ok, prop all good. Choked engine when applying throttle didnt help. for sme reason running rich when appling throttle to get boat o plane. Checked book for jets seems that this engine came from factory with different jets that book indicates. Mod 200stlens
Need help
basserjim2
Re: 1992 Evinrude 200 Xp very slow hole shot
tishdaddy....I dont have answers in my other post...you deleted them because I used my email address as a user name...thanks for everything that you have done to help me solve the problem.
Dhadley
Which jets are different?
basserjim2
High speed 62D, top 32, Idle air bleed 28 is this correct?
Dhadley
The book shows the air bleeds the other way around - 32 idle, 28 mid range.
