Engine ground
erikgreen
Quick question for all you guys I hope:
I can't reach the stud designated for ground on my engine (I think it's in the wrong hole, my fault) so I've been using one of my riser bolts as a ground for a while.
But in fixing my wire routing last night (it's a mess due to POs) I moved the main ground to the thermostat housing. Is there any problem leaving it there for a while until I move the ground stud somewhere useful? What's connected there is the black cable from the battery and one smaller ground.
Erik
PS: I also figured out that the trim sensor was connected back to back to the shift interrupt switch. Yes, I'm an idiot.
Fishermark
Re: Engine ground
There is no "magical" spot for the engine ground... but having said that, it really should be in the block. There are quite a few spots on the block that you can use instead of something that you have to remove periodically - like a thermostat housing for instance.
Coors
Re: Engine ground
And aluminum doesn't like electricity going through it to steel/cast iron.
erikgreen
Re: Engine ground
Gotcha.
I just moved it to a new spot attached to one of the exhaust manifolds. That'll work for the next couple months until I can pull the engine and move the grounding stud.
Thanks,
Erik
Don S
Re: Engine ground
Just remove a bellhousing bolt you can reach, may need a little longer bolt and put them all where they belong, move the stud later.
