My buddy has an older 50hp that has never run right. It will idle fairly decent, and run good at high revs in neutral. When put in gear does not seem to run properly. While in the lake the other day we adjusted the air fuel mixture screws on both carburetors with no change. However while running in gear it all of a sudden started to try and run proper only to die (ran out of gas) so if it ran good right when the gas was going out it seems that it is receiving to much fuel. A month ago had the carbs rebuilt in a shop but that didn?t change anything. It is never stored with fuel in it. How can we decrease the amount of fuel to see if that is our problem.
