Fuel line disconnect?
c_hawk
Is it necessary to have the quick disconnect fittings on both sides of the main fuel line?
Re: Fuel line disconnect?
no, built in tanks only have the motor connection. or if you have portable tanks, the tank end is ok.
c_hawk
I have portable tanks and there were the connections on both sides but fit loosely and leaked, so I went to NAPA and got some fittings to connect it all together. I wont have any problems will I?
Dhadley
Actually it depends on the motor. You don't "need" a connector on either end. Some tanks are set up for a quick connect, some have the hose fitting. On V4 loopers and all V6 & V8's the quick connect fitting is viwed as a fuel restriction. On smaller motors it's still a restriction but the motor still gets enough fuel.
did you put valves in the system to control what tank it draws from?
c_hawk
I actually have one tank. (typo,sorry)
