The primer only has 2 wires. A 12 volt lead and ground. The 12 volts (Purple/white stripe) comes from the ignition switch "C" terminal and the ground is to the engine block. Not sure if this is what you're after...
Thanks for the help. There is the purple and ground on the solenoid and another purple wire coming from the motor. I just dont know exactly where they connect onto the motor.
