Stonefly1967
- Joined
- Aug 7, 2008
- 7
This spring I had to change the transducer on my boat with the same model, it seemed a little high because I was getting a lot of spray off it hitting the rt side of the motor causing a skip above 30 mph. So I lowered down and the spray angle changed some but still hit's the motor, but the skip went away on 4 trips. I'm going to lean over and see for myself if the spray is caused by the transducer or the speed wheel, Now I fill up last weekend and get the skip back. I have a kicker I run trolling and have run that wide open on occasion to see if that would skip (water in the tank) and it doesn't. I haven't changed the plugs yet which I will do this weekend before heading out. It doesn't seem like the water hitting the motor should cause it to skip unless it was getting sucked into the air cleaner? When I pulled the hood off there was some small amount of water in the front of the motor, less then a soda bottle cap full, but we had hard rain just prior to me pulling it off.
Any suggestions??
Any suggestions??
