Evinrude Trouble
- Joined
- Sep 27, 2007
- 40
I have a 1982 70Hp johnson outboard J70ELCNB and i dont feel like i'm geting as much power as i used to. I have heard the alarm in the contorl box go off intermitantly every now and then and i know the motor has an optimal operating temp. When in WOT the motor sounds like somebody is moving the throttle a fraction of an inch back and forward in no particular pattern. Could this be the thermostat sticking open or closed? I know low temps lead to a carbed engine and i definately dont want that. Is there any way to test to see if the themostat is the culpert or does this sond like another problem. I have good compression and spark in all 3 cylinders and have recently rebuilt the carbs and fuel pump. I have been told that i could be "leaking spark" through my plug wires? Any suggestions on where to start?
