Re: not enough power
You will need to remove all the plugs, and ground out the plug leads. I like to hook the leads up to my multi spark tester, so that I can ensure adequate spark while testing compression at the same time, but simply grounding them to the block is fine. Some say to bring the outboard to operating temp, and advance the throttle, others say it is unneccessary. It seems to bring on debate, so I will leave that step up to you. Install the compression gauge into the first cylinder, then turn over the motor until the gauge peaks, usually about 7 to 8 cranks. Continue with the remaining cylinders. You should get an even compression within 10 percent on all cylinders, and the spark should jump the gap on the inline tester a good 7/16 of an inch with a bright blue ZAP!!
My guess is that you will find that you are not running on all cylinders, but I guess we will see.
