70 glastron 17 ft. trihull - project
duckee
Re: 70 glastron 17 ft. trihull - project
yeah i got a colorado ... the 4 cyl. ... im sure she can handle it ... and no we aint gonna win any races either ... lol
duckee
ok !! im gonna start buying some supplies !! but i wanted to double check my order with you guys to make sure im getting the right stuff ... all stuff is from US comosites ... the sheet i was looking at the 7 1/2 oz. E glass part # FG-C0738 ... the resin ... B-440 layup resin SMB440100 ... the epoxy ... 635 thin EPOX6355562 ... good stuff ? tight budget is limiting me to buying smaller qty. but ill at least have enough to get started ! lemme know ... thanks !
Hi Duckee,
I've been away from the forum for a couple of weeks trying to get my project done and balance the Honey Do list. Looks like you got your work cut out as well. John has been a great help in my project. V156 Glastron. I just finished putting down 3 of the 5 stringers. Glass over them and tie them into the transom. I covered them in Resin before putting in place with resin. I see alot of guys use PL to glue them down with. I was lucky with the stringer height as I was able to get them out in one piece or enogh of it to tracea template. I need to order up some foam tomorrow.
The grinding has been a job. Hope to have the floor in within the next to weeks. I haven't spent much money on this project, the biggest consumer is the time. Good Luck and keep us posted.
http://http://photobucket.com/bobandnicole
duckee
PL ? whats that ? lol ... lookin good though ... mines a V176 im getting super stoked !! gonna buy some necessities this week like a respirator ... cheap grinder ... brushes ... and maybe some other stuff ... and hopefully i can start next week buying the resins and sheet !! i will keep my promise and take tons of pics to keep all watchers posted ! thanks a ton for all the help and support !
oops!
Get your wood one of the frist things , you have to get it drying !
all the wood reguardless of where it comes from...(excluding marine ply from a real lumber yards....sold to you at whatever % of dryness)
needs to be dryed......i placed mine on a drying rack and hit it with a box fan...and stoked the wood stove...then rotated the sheets every other day....
drying plywood is a big part of the restoration.....
cheers
oops
duckee
so if i understand that correctly ... if i buy the more expensive marine ply ... then it dont have to be dried ? does it still have to be skinned with epoxy ? ... OR would regular ply skinned in epoxy be as good as marine grade ? if so how long does it take to dry ?
duckee
and ... is this stuff good ?
redfury
Best thing to do is to call the folks at US composites and talk to them about your order and what you are trying to do, they are the experts and can make sure you get the right stuff shipped to your door.
PL is a floor adhesive and it is cheaper to use than buying 3M 5200. There are different grades of PL depending on the use.
As far as the plywood goes, no matter what grade you buy, you will want to seal it well to avoid or at least drastically reduce any problems with rot, plus it will give you a good "primer" for the fiberglass to bond to...just give them a scuff before you start installing them to give the glass something to "bit" into.
jcsercsa
that looks good Duckee , you might want to get some heavier E-glass also !! I went with the 10 1/2 oz also !! other then that lookks good !!
what oops said on the wood is the way to dry it , I burned a fan out on mine !!
other then that sounds good !!! John
duckee
man you guys are awesome ! have i said that yet ... lol ... heck ill more than llikely say it again !! thanks again guys !
duckee
ok ... so i think i need to sell my project ... i need the money right now ... its killing me to type these words when a couple months ago i was super stoked about getting started ... but ... u know ... i cant take less than 500 for it though .... ive got around 800 in it ... let me know !
Striper Rig
Hey guys, Nice work on the boats...HARD WORK, but fun I'm sure it takes the mind off all other problems in life...
I'm going in the morning to buy a 1973 Glastron Swinger V176, it has new floor and new carpet, new seats, not sure about the motor, I was told it cut off on the lake and they didn't want to mess with it any more...will not run but I'm gonna check the compression on the cyl's...
The motor sounds a little big for the boat, 175 V6 power trim, I think the motor came out on the boat, but not sure...anyone know if that motor is to big for the boat?
I guess $500.00 is not bad even if the motor don't run, it has a ranger trailor that I will have to do a little converting on...
Anyone here with a 1973 glastron...
Great work guys.....
redfury
I have a 1975 V179, and I can tell you that the motor on that boat is too big. Mine is only rated up to 125HP. For 500 bucks though, you can part out that motor and make it back easily. I'd snatch that up if I had the cash to do it.
