TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
I'm trying to epoxy a PVC ring to the bilge of my 08 Maxum and after several attempts I'm about ready to give up. The most recent adventure involved sanding thru what appeared to be paint to get to the fiberglass and then using a quick setting epoxy (5 minute general use good for fiberglass and plastics type) and letting it cure for 24 hours. Once cured, I siliconed the inside of the joint, put some light oil in the ring and then the transducer. Everything was great the first 2 times out but she sat for a week and when I took her out yesterday, the ring was not secured to the hull and the epoxy was stuck to the ring.
This is my 4th attempt at getting this thing to stick so if anyone has a suggestion for how to make my 5th attempt more successful, definitely let me know.
Thanks.
Thanks.
