kwoolard
Thread starter- Joined
- Feb 9, 2003
- 420
I am looking for the ignition module plug connections for the 5.7 Alpha Thunderbolt V Ignition Module (861253-1). Can't seem to find a part number anywhere, I would assume they would come together as a kit.
For some reason my ignition module is leaking some sort of fluid out and is causing my module to short out while running on the water. I can pull the connectors off and a liquid will run out of the connectors and the module. I have cleaned the corrosion off and put dielectric grease on the connections, however, the water or some liquid still seems to make its way into the connectors and short out the ignition.
Therefore, I am looking to replace the module and the connectors together.
Anybody ever heard of fluid leaking out of the modules?
