tips on getting more horsepower on 4.3 merc
roblennox
I have the 4.3l merc engine would like to get more power what are some easy mods
roblennox
Re: tips on getting more horsepower on 4.3 merc
I have a 4.3l merc engine, looking for tips on easy modifications for more power
Don S
Not much to go on there, what year 4.3L Merc engine do you have?
roblennox
its a v6 its in a 19' four winns
Don S
I know it's a V6, and could care less what boat it's in, what I ask for was the YEAR of the engine, not the boat, the engine.
Uraijit
Banned
Nitrous Oxide! And LOTS OF IT! :eek:
wca_tim
:eek:
guess it would give you an excuse to step up to more motor... when you smoked the original with the bottle...
also, might be helpful to do some searches, there's a lot of stuff posted on here about that topic...
Ayuh,....
Vortec Heads,+ a 4bbl. Carb.......;)
mthieme
I have a 4.3 in my SRV190...nice setup...does 34 mph. I'm happy with that. One of my water buddies whom I grew up with has been trying to talk me into adding the extra two cylinders for years to wake the boat up. I'm glad I didn't listen to him with gas the way it is. I have a hydroplane for when I feel the need for speed.
One suggestion I have for you is to throw the crappy Chrysler points and condenser in the drink and get yourself a Pertronix CDI kit. I got an extra 1000 rpm out my little 4.3 (4400).
Bt Doctur
Sorry, but there`s no substitute for cubic inches
wca_tim
depending on which engine set-up you have now, you may be able to make s good bit of difference - bond-o's giving you the straight scoop. If you consider heads, intake carb, etc... simple upgrades.
if you want a lot more, and your boat can take it safetly, you need more cubes... That's to pull more power oiut of the engine. depending on what performance gains you're looking for, prop changes, etc... can be huge...
imported_TheMan
Doesn't the 4.3L have electronic ignition components anyway? i.e. no points to worry about.
MikDee
Banned
Simple cheap easy mods, for a bit more HP:
1) Put "Mobil one" full synthetic oil in, of the recommended weight (maybe 10-30W?) I have yet to find an over the counter oil that is slicker, I now use it in All my vehicles, (but I haven't yet tried Royal Purple, or Redline racing oil due to their price).
2) Put synthetic marine gear oil in your drive (the proper consistancy)
3) With the engine warmed up, & idling, adjust your idle mixture screws out usually counterclockwise to the highest idle speed you can get, and leave it there, you might use a bit more gas this way, but it's the best setting for power.
4) Make sure your flame arrestor is clean, I'd take it off, & clean it with a good spray carb cleaner, then let it dry & put it back on. I think K&N makes a low restriction flame arrestor if you want to go that way.
5) Make sure you have good metallic core suppression spark plug wires on there, and new spark plugs for a healthy spark, a new high perf coil would help (MSD/Accel).
6) Make sure you have the right prop for the load, under, or overpropping, will defeat any mods, and wear your engine out fast.
6) wax, or polish your boat bottom if you can, this always worked for me, despite some naysayers here :rolleyes:
Aside from these, you'll need to get into the engine mechanically if you need more HP, Bond-O had the best suggestion! ;)
Don S
Some do, some don't, some also have Vortec heads and roller cams, some have EFI, some have carbs.
That's why very early in this thread I asked the question "WHAT YEAR" it was, and never got an answer.
