I am having a problem with my outboard. I just bought a used boat and it came with a 97 25hp evinrude. I have used it every weekend for the past 6 weeks crabbing(6hrs per weekend). Mostly idling around, but I try to clean out the carbs occasionally by taking a spin on plane. The past 2 times out it has been smoking pretty bad (more than normal). The most recent trip(8/9/08) I burned an excessive amount of oil. It has the built in tank which I filled before leaving. I noticed the red indicator light (low oil) blinking while checking the traps. I filled the tank again about half way through the trip. Right now it is sitting a little above half. I burned about 3.5 gallons of gas the entire day. This should only require ~8 ounces of oil. I am not sure how much oil the built in resavoir holds, but it is signicantly more than 8 ounces. I estimate that I burned a little less than one whole resavoir of oil using only 3.5 gallons of gas. I also noticed a small problem which never occurred before. While trying to get on plane to return to the ramp the motor felt sluggish and stalled a couple of times. Previously to wrapping up for the day we shut the motor off to debait all of the traps(~20 minutes). I had to let it idle for a bit before being able to get on plane. This had not occurred before and I ran around about 5 times to check out other areas on Saturday. Any suggestions as to why I would be burning so much oil.
On a side note I am noticing a decent amount of oil draining from the prop while sitting in my garage. I read this is normal...
The motor has ~60 hrs according to the guy I bought it from and it sat for at least the entire year of 07 up to July of 08. It may have been longer as the registration on the boat had run out in 06.
Any help is appreciated.
Thanks
Scott
Thanks
Scott
