Re: lower unit
hi joe or frank,i pulled my boat out tonight,and did some more investigating in the driveway,im sorry i gave you some wrong info,and this is what i found so far,on the lower rod disconnected.i can not get it to move into reverse it seems like it tries because the prop tries to lock in but seems like it just tightens a little bit but does not fully lock in and i think this would be in the up position,on the rod, then moving the rod down into neutral no problem and then one more notch down to forward no problem so im thinking the lower rod will not go all the way up to engage in reverse. any thoughts on this would help very much . can you guys stear me in the right direction on what to do.i also marked the distance on the lower rod where it connects to the upper rod and the throw is not the same at all with it hooked up or disconnected , thank you , ken
