alpha one swap issues
ewg302
Alright.....heres what I've got. A 98 searay 175 that has no outdrive....and 89 searay 160 br that has no stringers left. It would be great to swap the outdrive from the 89 to the 98...but I've been told it won't work. Any ideas? I have everything on the 89.... motor to propeller.
Uraijit
Banned
Re: alpha one swap issues
How much time and effort are you willing to put into this?
ewg302
By the way you phrased your response........I am worried.....I am willing to make it happen. It would be great to get running with what I already have. What would it take?
ewg302
I guess I am dissapointed that I dont have the easy fix I thought I did. Logically selling the 89 and buying the outdrive makes sense......but then my project seems to have failed. I guess I ll have to get over it. It seems like there must be away to use the newer motor with the older gimbal housing and drive. What are the differences?
Ayuh,...... That's Doable.....
Swap everything from the Flywheel Cover back,+ the T-Stat housing.....
It'd be nice to know just What the 'ell We're workin' on though......
ewg302
Yeah, that would help. Its a 3.0 mercruiser alpha one. Sorry.
ewg302
OK I am considering doing the swap. Would the motor have to come out? Can you remove the gimbal housing and the flywheel housing with the motor in the boat? Also is the transom mounting the same between the new drive and the old drive? I would love to be able to knock this out over the weekend.......correction, my wife would love for me to be able to knock it out over the weekend.
ewg302
Can anyone tell me what is preventing the swap. What physically prevents it from working? I found out that the shifter linkage is different and the trim mounts are a different width. Can I swap the trim rams and replace the linkage.....Thanks, I know someone must have tried this before.
