Method of hooking bait for trolling
Btuvi
What method do you use to hook a live trolling bait to avoid line twist?
Fly Rod
Re: Method of hooking bait for trolling
Your line should not twist when using live bait. Why would your line twist if they are swimming?
triumphrick
Usually the hook is passed from below the bait up through the head or bill (ballyhoo). Also I have used a few twists of copper wire on the shank at the bill of the bait. I usually do not exceed 3-6 mph.
gcboat
The main cause of line twist when trolling baits is excessive speed. Slow down - problem solved.
frankie g
adding a quaility swivel between your leader and line will help as well.
