Re: johnson 60hp hydroelectric drive
Got brave and dropped the lower unit, good thing too, Water pump impeller totally destroyed. Woodrife key below plate, rubber in plastic drop tubes.
The solinoids are functioning, cleaned each, but at closer look(someone has disassembled before me)it appears the solinoids have been reversed, would this cause a problem, and is there a return spring somewhere, other than the spring washer on the top of the unit? Going to get parts for the impeller unit now.
