1998 Yamaha 9.9 4 stroke idle problem
timberwood
The motor runs fine with throttle, but will not idle. Is there an idle mixture adjustment?
Thanks
garyN
Re: 1998 Yamaha 9.9 4 stroke idle problem
You have a gunked up carb - very common and annoying - as you have to remove the carb and have it "cleaned" - but then it will do it again and again.
See my post - They should put wing nuts on these carbs
