does anyone run an air filter?
rthomas
i seem to be having a problem with lots of dog hair and dirt collecting around the spark arrestor and inside of the carb. of course i need to keep the spark arrestor and am thinking of something that would go around it. any ideas??
medic181075
Re: does anyone run an air filter?
K&N makes a USCG airfilter/flame arrestor for some applications.
cgrooves
Is there a lot of dog hair and dirt in your bilge area? I don't see how you would really need an air cleaner with a clean bilge.
Uraijit
Banned
Reason #637 to leave your dog at home... :D
ziggy
couple years ago, my buddy put a K&N on his 4.3. he had the same problem, dog hair. the K&N came with a foamy spongy thing that went around the FA. guess he liked it better to clean that than the FA..... oh, his bilge was spotless. always 2 dogs onboard though......
mkast
I remember reading somewhere, marine applications don't normally use an air cleaner because of the fire hazard.
I use a USCG approved K&N.
ziggy
best of my knowledge, that's what it was. a K&N, uscg approved, fa, with a foam piece that went around it. and your right. marine don't use air filters, no need for them. generally speaking.... except for dog hair apparently..... myself, i don't know. i got cats + an oem mercruiser fa which i like just fine......
mkast
I think if fire hazard wasn't there, you would see air cleaners on all boats.
Clean filtered air is important to the engine.
wca_tim
what he said... it doesn't take many pieces of dust... especially sand / silica to wear away some metal where you kinda wanted to keep it...
Don S
Been a marine tech for many years, never seen an IO marine engine worn out. They always die from water, lack of maintenance, freeze damage, or over-propping. But never worn out.
EDIT: dog hair will not go thru the FA, or destroy the engine if it did.
