wildmaninal
- Joined
- Jul 14, 2007
- 1,897
First off let me tell ya I have been worried about getting this boat painted for the longest, been using the boat just like it is for some time now. I figured that these white spots on the hull was where the previous owner sanded it down to bare fiberglass. I started sanding with heavy grit on the hull on those white areas that I thought was raw fiberglass so I could spray some primer on it and next thing I know I started revealing the original paint underneath. I feel like such a goof, because I didn't know that was primer all along.
I sanded it down in spots and I had some old (I mean old) car wax that I put on a rag and buffed into the original paint and it helped bring back some shine but not much.
One of the problems that I have now since I started off with the heavy grit sand paper I scratched the original paint that was below the primer in several spots.
Is there a way to buff these scratches out?
Or should I continue to sand down the original paint with a finer grit sand paper to get the scratches out and maybe try to bring more shine back in the paint?
What type of wax should I use? Or would clear coating it work instead?
Here are some pics. My boat is due for a wash and a vacuum cleaner
You can see in this pic where I sanded the area down to the original paint and applied the old wax from the trolling motor and on to the right of the bow light. Also if you look to the right by the anchor winch you can see where I have been sanding and revealed allot of the original paint there as well but haven't applied any wax yet.
This last picture of the livewell doesn't do the paint any justice, the paint in this area looks like new, and has never been touched.
