Re: Warm up lever movement
Not to hijack a thread, but I've got the same problem with mine only it happens when coming out of reverse. I haven't taken the time to address it yet, because it's only a minor annoyance. Sounds like adding a little slack to the cable is worth trying though. I'd figured it was due to lack of lubrication in the controller.
I'm in the same boat (pun intended). My motor won't idle well so when I come out of gear I don't mind the warm-up going up a bit. Shoots my idle up to about 1000-1100 when I come out of gear and then I just bump the warm-up lever down to get a good idle without stalling. Plan on fixing the idle issue this fall, assuming it a carb issue. I keep my cable a bit over tightened to get maximum movement on my warm-up lever allowing better starting.
But, none of this helps tbharris, I suppose.
Still...I believe that his problem is a symptom of a mis-adjusted throttle cable. I don't have the proper steps to set up the throttle cable correctly with me at this time so hopefully an expert will chime in with the right steps to set the cable correctly for that motor.
Hopefully that's it, cuz it's an easy fix
