jbmarley30
- Joined
- May 15, 2008
- 19
Hello Everyone,
Looking for some help for a while now. Here's my situation: My motor bogs out when accelerating past half throttle. If I don't bring it back down to trolling speed it will stall out but I have no trouble re-starting. The other day it accelerated for about 5 seconds then stalled out. I've replace the following- fuel line, filter, pump kit, tried separate clean gas tank, replaced both CD Boxes, rebuilt/clean carbs, new stator and flywheel. FYI- all cylinders are sparking, compression is fine, primer pump holds some pressure while running. I've had the idle and carb set by a mechanic. He thought everything was fine when it idled in his tank the other day.
Any suggestions?
Thanks
Any suggestions?
Thanks
