I'm having trouble finding the cause of a leak that is empting my reserve bottle for the outdrive on my 94 Maxum with a 4.3 . At first I thought that it was in the outdrive,but now I know it is leaking into the boat under the motor. I have removed the reserve bottle and filled while capped off and watched for leaks,none. I removed the hose and clamps that lead down to the inside brass fitting and vacum checked hose,ok. I renewed the clamps on install with good fuel injection clamps. Same condition. My outdrive unit stays full of clear clean lube but the bottle empties into the back of the boat. I believe that I can see the 90degree brass fitting and where it tightens into the transom body and feel that that seems dry. It appears that the leak is just below that area. What could be my problem? Could there be a crack in the housing ect. I'm hoping that someone has seen this and has an explanation. I have had similar stern drives for 30 years but this is my newest with a reserve bottle and right now I'm leaving it empty and using it like the old ones with just filling it to the vent hole from the bottom fill hole and it stays that way. Thanks in advance for any light on this subject . Tom
