rfdfirecaptain
- Joined
- Aug 17, 2008
- 314
1993 Volvo 7.4 ltr. / DP-D outdrive
I'm trying to remove the steering pin to roll back the steering helmet on my outdrive. I have a shop manual for the DP-C outdrive and it says to take (2) 6m x 30mm bolts and insert one into the holes on the left and right sides of the steering pin. Supposedly, this will force the steering pin out. Is this the same procedure for my DP-D outdrive as well. It looks the same as the photo in the DP-C manual? Well, I don't have any bolts of that size and I don't know where I would find any. Even so, I don't see any threads in those 2 holes, only a white powder that looks like corrosion. Are there any other ideas to remove the steering pin?
Also, I don't have the "special tools" this manual calls for to remove the pins that connect the hook-up fork to the transom shield. Any ideas how I can remove those pins with ordinary tools? Which way do they back out, inward or outward?
Thanks!
Keith
Thanks!
Keith
