Bolt/washer material thru aluminum transom ??
Kymasabe
I'll be replacing the transom on my little 12 foot aluminum boat soon, as slowly gathering all the material I'm going to need and was planning on picking up the bolts/nuts/washers this week but thought of a potential problem. Will stainless steel bolts and washers be a problem thru the aluminum and on the outside of the boat. Will the stainless washer react with the aluminum? I will be sealing everything with 5200 or possibly 4200 so that might insulate one metal from the other, though I doubt it. I considered rubber washers but thought they'd eventually compress, causing the bolts to loosen and possibly egg the holes thru the aluminum.
Or...am I worrying unnecessarily and stainless thru aluminum and washered agasint aluminum will be fine?
Is there such a thing as an aluminum washer and should I use one?
Also...exterior...should I use standard size washers or fender washers?
Re: Bolt/washer material thru aluminum transom ??
i use fender then standard on top of the fender.
Tim Frank
I am facing the same thing.
The original bolts on my transom were aluminum, and there is enough separation between stainless and aluminum on the metal activity chart that I think that staying with aluninum is the way to go.
They are available from any good fastener shop. The place I got them had to special order, but they arrived in two days.
They are also available on-line.
I am not familiaer with 5200 or 4200 sealer. What are they?
tmcalavy
Marine sealants...available at Wally World and other places.
