I replaced the plugs on my 95 28HP Johnson today. I have attached pics of the plugs I removed. Do they look normal? I was thinking they looked fouled.
I was also able to get rid of the "lean sneeze" at idle by adjusting the low speed screw out, although when I came back later it started sneezing again so I had to adjust it again. I had put some SeaFoam in the gas so I'm thinking maybe some gunk got caught in the needle and messing with it cleared it out. I know I need to clean the carb, but I'm hoping to nurse it through the season and do it over the winter.
I still cannot get it to throttle past half throttle without dying. I tried squeezing the primer bulb as I throttled it up and it still died so I don't think it's the fuel pump. Would a clogged high speed orifice cause this? (I don't think I have a high speed adjustable needle) Could someone confirm whether I am correct in that my carb has only one adjustable needle valve? Can I remove the high speed orifice, clean and put it back in without tearing the carb apart?
