loosing power with a seahorse 9.9
BOATIN'BOBBY
Hello all,
I have what I believe to be a "85" model seahorse, It idles really well and runs good at lower power. My problem is when you get it above roughly half power . It just shuts down.However if I pull the choke out it will continue to run. I have had the motor for a coulpe of years and last year it preformed great. I have already checked the tank to motor fuel lines for air leaks with no luck and the ball stays tight. Thanks in advance for any thoughts.
tx1961whaler
Re: loosing power with a seahorse 9.9
Sounds like the high speed jet in the carb is clogged up.
david_r
yup...im with tx time for a good cleaning or rebuild on the carbs.
if you let it sit you need to use fuel stabilizer this wiil reduce your chances of having to do this every year.
BOATIN'BOBBY
thank-you for your responces, you were both right i tore down the carb tonight and sure enough it was filthy. I cleaned it out and rebuilt it. While I have not got it on the lake yeat it sounds good in a trash can. Thanks again
