lower unit small hole
betayv
hi there I replace my lower unit because was crack, I replace the water pump on my new lower unit and the question is in the lower unit at the front of the housing is a small hole, before I never see water coming out of that small hole is that normal and what is that hole for? thanks
achris
More fish than mountain goat
Re: lower unit small hole
I assume you are referring to a Mercruiser... The small hole low on the front of the lower unit is a drain, nothing more. The reason your old unit cracked, was because that drain was blocked and allowed salt/ali corrosion to 'grow' inside the cavity.
Chris..........
ziggy
and it looks like this when on the hose...
next time ya go after your impeller. clean this cavity out. both the used drive i have gotten have had this cavity plum full of sand and other stuff. very hard pack.... i used a long screwdriver + a small hose attatched to my vacum cleaner.... a small wire thru the hole after ya clean it out....
betayv
hi there thanks crack because I hit a rock but the problem is that I replace the water pump and when I turn the motor with the hose I have water coming out of that hole is that normal?
achris
Normal and a good thing... it shows the drain cavity is clear....
betayv
by the way I forget to put back 1 of the screws on the water pump that will cause problems right?
ziggy
i has only has 4. i wouldn't be happy knowing there were only 3.... this is the sorce of where the water comes from to cool your engine.... i'd go put it back if it were me.... use proper torque values on the bolts... next time, i would guess you won't forget that screw....;)
betayv
yes I see is 4 I only put back the 3 and start the motor with the hose and was overheating a little bit.
Ayuh,.....
You just Can't leave out pieces,+ expect anything to Last.....
You can either Fix it Now,...
Or you'll be Fixing it Later,....
And probably alot more than Just a Screw if you wait for Later.....
Don S
It doesn't matter one bit which one you forgot. It needs to be fixed before you take it out on the water.
It's just that simple.
betayv
hey thanks to everybody for the help tomorrow Im going to take it apart I will take some pics and see how will work thanks.
