Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
In the process of setting up my first real boat. Its an older boat with an outboard but the hull, floor and transom are in fantastic condition. Redoing the complete interior, plus all new wiring, adding power trim and bilge pump as well.
While installing the bilge pump a concern came to mind and thought I'd ask the members opinions here.
The gas tank, battery, power tim pump and bilge pump are all located under the splash well, as is typical of most all outboards I'm assuming. This area is closed off from the passenger area by a vinyl barrier that is snapped in place. This effectively creates a closed area.
Is there danger of gas fumes accumulating in the bilge area?
Should I install a blower like is used on I/O's? Am I concerned over nothing? What is typically done with outboard setups regarding venting this storage area?
