on the muffs
cjduns
this may sound stupid but i am new to boating, i have a 70 hp chrysler o/b when i have the hose on it , seems like no water goes in the engine does it need to warm up first or should there be flow right away? I have a manual orderd but i'm impatient thanks.
eurolarva
Re: on the muffs
Hello cjduns and welcome to iboats. Chrysler lower unit design usually does not work well with most water muffs. It is best to build a water test tank using a garbage can or something similar.
godfather318
Re: on the muffs
once engine starts you should see water coming out right away, if not check impeller in lower unit, otherwise you will burn out your head unit.
