Alarm problem
Mark1962
I have a 115HP Yamaha outboard, year 2000. The alarm goes off when RPM get above 1700. I have replaced water pump, oil level sensor, cleaned the oil filter, removed thermostates from both heads, and disconnected both temperature sensors. The alarm continues to go off.
Please help I am getting ready to use as an anchor.
Mark
JUSTINTIME
Re: Alarm problem
if u pulled the temp sensors, then u know it is not those
does it go into rpm reduction mode
Mark1962
Re: Alarm problem
yes the engine goes into rpm reduction mode, the engine temp after removing the thermostats is cool to the touch,
Yamajoe
Re: Alarm problem
Replace your thermostats, check your pressure control valves, clean them out if in a bad way, replace and be careful when you replacing it , as you can push the ball into and past the groove, check the wiring on oil level sensor.
