Darren Nemeth
Thread starter- Joined
- Dec 25, 2007
- 561
Hello, all,
Winter is coming on fast and I need help before it gets too cold to glass.
Here is where I am at. I ground off the old, rotted transom off my boat and have several problems / questions that I need help with before I feel confident in replacing it.
The first is that I am completely new to grinding fiberglass boats with a grinder. As you can see in the attached picture I got all the old transom and paint off BUT the surface is not smooth at all. In several spot I even ground down to the gel coat.
What do I have to put on this to make the hull smooth enough to properly and correctly laminate the new transom to it?
As it is right now, there will be too many gaps between the hull and marine ply.
Second issue is this. I read all the info here about what type of glass fabric to use on laminating in the transom wood pieces together and to the boat but not a definitive cloth weight.
My boat is a 14 foot 1969 Glastron V-145. The template I made is 58 inches at its longest point and averages 16 inches in height. The heighest point is 21 inches. Not a large transom at all.
Is a lighter weight glass cloth inadequate? Is a heaver weight (which will soak in much more of the expensive epoxy) too much? For my boat, what is the appropriate weave of cloth I will need? And weight?
I want to get started on this pronto but am not 100% sure or confident about these two things.
I have the "Runabout Renovation" book by Jim Anderson but it also does not give specifics on the appropriate weight of cloth needed, either.
Thanks in advance.
Thanks in advance.
