1976 55 evinrude water pump
nathansim
i just bought a little runabout with a 55 evinrude on the back i was wondering if anyone could tell me why no water shoots out when i put the tap water on it in idle . should there be a stream of water coming out near the top?
F_R
Re: 1976 55 evinrude water pump
It should blow water droplets out the exhaust relief holes in the backside. It will also blow water out through the propeller's big center hole. There is no "stream"
Randybeall
If you want to there is a very good description of how to add the tell tale in frequently asked questions. Done correctly it will eliminate the possibility of air lock in the engine as well as give you the piece of mind of seeing the water flow.
nathansim
cheers mate as you can tell i now know its called a tell tale lol you must think me as stupid as a photo copier
