racemonster
Thread starter- Joined
- Aug 18, 2008
- 5
Ive had my boat for a little over a week now and been learning alot on this site ever since I got it.
I wanted to check my RPMs at WOT.
My tach read 7000 RPMs WOT (1991 Johnson 115HP on a 1990 Smokercraft 17 footer)
That number was a little unbelievable to me.
So the next day I put a tach off of a Racing Kart on the motor,
This tach is made for a single cylinder motor though.
I am assuming that each Cylinder on the Johnson fires once every four Revolutions?
Now because the Racing tach only tells my how often the one spark plug I can connect the tach to fires, I am getting a reading of 4300 RPMs
These are the numbers I found on my current Prop 13-1/4x19
The Speedo in the boat reads 30 MPH and the Speed matches what the fish / depth finder says.
My boat did come with a spare prop it has these numbers on it 14x17
In researching this site. I believe the motor would run best between 5000 and 5500 Rpm?
Am I correct in thinking that the 4300 RPM is more believable than the 7000 RPM? or is it more beliveable that neither is correct?
Any dirrection on the best prop wold be greatly appreciated.
Thanks
Rob
Thanks
Rob
