72Glastron75Merc
Thread starter- Joined
- Aug 25, 2008
- 8
I have a 1975 Merc 650 with a few problems... 1 identified, with 2-3 still lingering. Once started, it holds an idle fine, I can play in the 1000 - 2000 rpm range with no problem... once I hit 2000, I need to tap the choke every 200 - 300 RPMs until I reach 3000... then everything is fine from 3000 - 5500... As for the other issues, I realized there was a pin hole in the fuel line between the fuel filter and the fuel pump... I have that part on order for this week, however, i think the rpm issue is unrelated. Additionally, I get some smoke at low rpms... (1200 - 1600, and only when in gear).... and while I have you hear... I have the idle set at 1000 RPMs... anything lower than that stalls out... Please help me fix my baby!:redface:
