Mercruiser 3.0 Reliability?
scotttu
Thinking about buying a 2005 Bayliner 175 with the Mercruiser 3.0 in it.
This is a 4 banger? Looks like it from the pics.
Having had a VOlvo Penta I want something a bit more reliable and cheaper to fix should it ever need it....
Is this fuel injected, throttle body, or carbuerator??
THanks,
Scott Turchin
Bathtub Racer :)
JB
Re: Mercruiser 3.0 Reliability?
Not an outboard, scott.
Moving to I/O
Fishermark
This is a 4 banger?
It is a 4 banger and is a simple, dependable engine. Easy to work on and parts are easy to find. Nothing in a boat is "cheap" (at least not in dollars ;) ) but the parts will be typically more inexpensive than others - like Volvo.
enn858
Same base engine as the VOLVO penta 3,0 (it`s a GM Vortec 3000 4 cylinder)
It is a rather simple engine carburated etc.
And yes if maintained it is very reliable
The drive is a Mercruiser Alpha one gen 2 also a bulletproff choice very reliable and in numbers the most common stearn drive in the world
scotttu
Thanks, exactly what I was looking for!
4 banger is enough to pull a tuber and go drive around Puget Sound.
Just need to make time to go look at it!! :)
Uraijit
Banned
I'd be more worried about the reliability and condition of the hull, than the engine. Bayliners are notorious for floor/stringer rot, etc...
Caveat Emptor!
scotttu
Caveat Emptor!
I had a 1986 boat that was JUST starting to see that. it lasted 20 years.
This boat I'm looking at is a 2005 that has been garaged except when in use.
Going to go look at it soon though....
chiefalen
Check the oud rive oil. Check the motor oil. Look at his records.Maintained right the engine will outlive you.
Make sure you take a test ride.
Good luck!
Uraijit
Banned
Okie Dokie. Just saying... That engine is more solid than most hulls, let alone a Bayliner.
If it's been stored indoors, or had a good cover, everything's probably hunky-dory.
Of course, ANY boat that's not cared for properly, will not hold up as long.
The fact that it's a relatively new hull will probably be in your favor though.
Good luck with your new purchase!
