Jbrazington
Thread starter- Joined
- Aug 25, 2008
- 4
I have an 89 mercruiser MCM 3.0 with Alpha One outdrive. I can start it in neutral fine, and even run it up, but when I put it in gear, then throttle it up, it bogs down at around 1500-2000 rpm. I can hold the choke butterfly closed about 3/4 way and she takes off, but when I let go she bogs down again. I have adjusted the idle mixture screw out 1-1/4 turn like recommended, then adjusted up and down with no avail. I don't see any other mixture screws that I am aware of. Any ideas of where I should start?
Mercruiser MCM 3.0 Litre
181 CID
130 HP
Transom S/N 0c591342
Drive s/n 0c547644
Carb 1389-9562 3.0l 2bbl
181 CID
130 HP
Drive s/n 0c547644
