allingeneral
Thread starter- Joined
- Aug 26, 2008
- 81
Hi All,
I have a 1989 Sea Ray 220 with a 5.7L Mercruiser and Alpha 1 outdrive. It has worked wonderfully for me for the last two years.
This past weekend, I took the boat out and it worked fine all day, up until the very end of the day. I was cruising along at about 20-22 mph, on plane, enjoying the wind in my face, then suddenly, the engine roared and the boat stopped dead in the water. I almost ate the windshield from the sudden unexpected stop, then grabbed the throttle and pulled it into neutral.
Now, any time there is torque on the system, it drops into neutral. I can take off very slowly and get it up to about 2500 RPM before it happens. If I punch it (as if to pull a skier out of the water), it immediately occurs. I couldn't even run the boat up on the trailer yesterday because it won't stay in gear under load.
Can anyone point me in the right direction as to what the problem may be and how to correct it?
Thanks in advance!
Rick
Thanks in advance!
Rick
